135mm wide Fork
12 replies [Last post]
Paruig's picture
Paruig
Offline
135mm wide Fork would allow the use of either Rohloff Speedhub or SRAM DualDrive - a great improvement over derailleur systems.
Road wheels (130mm) could be used with the use of spacers as in some other designs.
What about redesigning the fork for 135mm hubs and wider tyres John?
baov's picture
baov
Offline
Share
Don't think it will happen
Don't think it will happen ever. They meant the Silvio to be a race bike and nothing more.
I wish though, if the Vendetta is already a race bike, the Silvio should be the versatile bike.
John Tolhurst's picture
Offline
Share
The new fork is 132.5. Some
The new fork is 132.5. Some road bikes are coming out with 132.5 so they can take 130 road or 135 hubs with disk rotors. This new fork should accept an internally geared hub (IGH).
As to whether the IGH is an improvement over a derailleur system, that depends entirely on the goals of the rider. It would not be an improvement on MY Silvio, for example.
__________________
Architect, Planner, Business Analyst. Cruzbike original designer, inventor, proponent, technical curator, keeper of the mission.
baov's picture
baov
Offline
Share
It's true a 132.5mm distance
It's true a 132.5mm distance could fit a 135mm hub... on steel. I'm nervous about spreading aluminum. Will i void my warranty by putting in a 135mm IGH? laugh
EDIT: Did you say disc? I wasn't sure from the picture if i was seeing disc bosses and it didn't say from the specs. It should be advertised!!
Rick Youngblood's picture
Offline
Share
Disc tabs have been standard
Disc tabs have been standard on both the Silvio 2 and Vendetta 2 for a while now, it's not something new, however the 132.5 mm fork is new to this generation of Silvio S30. And I believe on the next generation Vendetta?
__________________
~ Rick Youngblood
Redding, CA {Who'll Stop the Rain}
2014 Silvio 2.1 & Vendetta 2.0
www.RickYoungblood.com
BentBierz's picture
BentBierz
Offline
Share
Is the 132.5 an option for
Is the 132.5 an option for older 2.0s and I am curious as well about spreading the fork albeit only 1.25mm on each side.
__________________
Larry
Friendswood, TX (Houston Metro Area)
'13 Cruzbike Silvio 2.0 | '13 Barcroft Ti Virginia | '10 HP Velotechnik Scorpion FS | '10 Easy Racer Folding Ti-Rush | '02 Airborne Ti Carpe Diem
BentBierz's picture
BentBierz
Offline
Share
Nothing?
Nothing?
__________________
Larry
Offline
Share
The 132.5 is available in the
The 132.5 is available in the PRESENT edition. Earlier editions have 130.
If you are asking if we can upgrade old editions kind of like software, then nope. Smile
__________________
BentBierz's picture
BentBierz
Offline
Share
Roger that...
Roger that...
__________________
Larry
georgec's picture
georgec
Offline
Share
FWIW I installed a Nexus 8 speed IGH in a Silvio
FWIW I installed a Nexus 8 speed IGH in a Silvio (v 1.5?) bought ~26 mos ago.
I ground the Nexus 8 "lock nut for left hand cone" down to reduce its thickness. This reduced the assembled width of the hub to ~133 cm. I also modified the dropouts to accept the Nexus no-turn washers.
Some details are shown here...
http://cruzbike.com/gates-carbon-drive-geared-hub
However, a problem with this approach of grinding the thickness of the no-turn washers down is that it weakens them and one of them failed on me.
So, a year ago I improved the dropout modification by boring completely through the dropouts and modifying the Nexus axle nuts to allow use of un-modified nexus no-turn washers and a large retaining washer for the dropouts. I also installed a chain tensioner by boring and threading a 10mm hole in one dropout. Since then this modified dropout IGH hub scheme has been totally trouble free.
The fork does have to be sprung ~2cm to get the hub in. But this has been no problem so far.
George
BentBierz's picture
BentBierz
Offline
Share
John Said...
"If you are asking if we can upgrade old editions kind of like software, then nope.  [Smile]"
I might belatedly add that, "nope", I was not thinking of an upgrade like in the software world (this is after all a bike forum) but more like what ICE, HP and any number of other "bike" manufactures frequently offer as upgrade options to previous model customers...
__________________
Larry
jcarol's picture
jcarol
Offline
Share
The new high-tech HAPIfork is
The new high-tech HAPIfork is pretty costly as eating utensils go. But this one is actually the latest gadget launched to the country's multibillion dollar a year diet industry. The fork, introduced at the Las Vegas Consumer Electronics Show in January, measures eating habits and alerts you if eating too much or too easily. It may well be worth its price tag if it works where other devices have failed. A little cash can help you pay for your new silverware.
castlerobber's picture
castlerobber
Offline
Share
JCAROL is a new poster, selling stuff
But is the HAPifork 135 mm? Can you eat SPAM with it?
"Lovely spam! Wonderful spam!"
"I don't like spam!"
