Assembly Pack - SRAM Rival
SRAM Rival, an excellent and affordable road groupset from SRAM.
Choose this option and we supply this groupset.
The double chainring is available as a "compact" (34 x 50) or full-size (39 x 53). If you have steep hills, the compact is preferred. Combined with an 11 x 28 cassette gives a nice range of gear ratios. The standard crank length is 170mm, but you may specially request a different crank length (such as 172.5 or 175 mm). Please email special requests to cruzbike.service@gmail.com , or put your order preference in the order comments section when you order.
The SRAM Rival Groupset includes:
- Sram Rival DoubleTap Shifters
- Sram Rival Braze-On Front Derailleur
- Sram Rival Rear Derailleur (SHORT CAGE)
- Sram Rival Brake Calipers Front & Rear
- Sram Rival GXP Crankset (53/39 or 34/50 in 165, 170, 172.5, or 175mm crank length)
- Sram Force PG1071 Cassette (11-28)
- Sram GXP Steel BB Cups (English)
- Sram PC-1071 Chain
The only things you'll need to add to get riding this bike are wheels and pedals.
If you order the A67 wheelset, you'll also need rim tape, tubes and tires.
The groupset is not assembled to the frame, because the frameset ships packed down to save shipping costs.
