Component Option
3WHELZ
Has any one considered the use of the SRAM WiFLi for a rear to cassette to compensate for SRAM's lack a road triple crankset? I currently have all Campy components with the Comp-triple crankset on my 1.0. I find the need for the smaller chainring on some of the larger ascents. I am weighing the options should I decided to purchase a 2.0.
Thanks
Drew
I just ordered the Wifli RD
I just ordered the Wifli RD with an 11-32 cassette and the gear range comparable to a triple. Im going to run a 52/36 chainring with 172.5 cranks
Andrew 1973
I have a Campy Triple too...
...and so far, I have never used the granny gear. I prefer doubles to triples anyway and the WiFli system has a definite appeal to me in that regard. The only downside I can see is the compact crankset; I need a 53 x 11 combination at times to keep from spinning out.
I belive Eric used a long
I belive Eric used a long cage MTB rear derailleur on his Vendetta so he could get an 11/36 on it. There's no reason WiFLi wouldn't work
That being said, I think you guys are all nuts for not putting on triples. Either the hills in my area (or my aero-belly) is bigger than what you guys have... :D
No, I used a SRAM X9 TYPE 2
No, I used a SRAM X9 TYPE 2 mid cage which can accommodate my 11-36. The WiFLi only handles up to 32T.
My X9 TYPE 2 also uses a roller bearing clutch which does indeed seem to smooth out derailleur bounce and chain slap as advertised. I was definitely putting it through its paces at the HPV races.
I also like the cage lock feature. It is just a spring loaded pin that holds the cage in the open position after you've moved it there by hand. Makes getting the wheel on and off MUCH easier.
I'm running 53/39 front and can spin it out in some cases. So far I'm really liking the 53/39 and 11-36 combo but still haven't hit very long hill durations. May have to take a road trip to Prescott one of these days and try and keep up with Dan :)
thebean
What is the WiFli??!  And the
What is the WiFli??! And the two wheel sizes are interchangeable on the Quest?
