Cruzbike bracket length
Shahmatt
Hi all,
Need an urgent answer to this. I've asked this question over at the Conversion Kit forum but I presume John and others have not seen it yet. So repeating here with apologies.
Can anyone tell me what is the length in the image? I need to know what can be the maximum length between donor fork dropout and the Cruzbike bracket dropout .
This is in order to make sure that the donor I want to buy is ok. ?A prompt reply is most appreciated.
Vargas
I have positioned the hub
I have positioned the hub (wheel) at the right end of the slot which appears at the left side of your picture; this is the maximum position you can insert the hub.
The distance from the last hole on the right of the picture, to the hub quick release is 10 cm. I could still move the hub another 2 cm towards the front (to the left of the picture) along the slot.
So you may consider something from 10 to 12 cm.
For what it's worth, you
For what it's worth, you probably didn't get an answer because you posted in thread on another topic.
As far as the answer, I see nothing wrong with i009899's response.
Shahmatt
i009899,
Thanks very much for
i009899,
Thanks very much for the info.
Charles,
Yes. Didn't really want to start another topic if I could help it.
Shahmatt,
Actually I somehow
Shahmatt,
Actually I somehow missed it was you who posted (I was too busy being grumpy...).
Given that it was your thread to begin with...
Grumpy Charles :D
Shahmatt
Charles,
Ah! Hehe! Didn't
Charles,
Ah! Hehe! Didn't notice any grumpiness at all actually. So no worries. Cheers!
