First and second flat, same ride
First time changing the front tire on the Silvio. For anyone else with an S30 - the first time you remove the front wheel, it's stuck in there pretty good. I ended up having to pull the fork apart a bit to loosen it up. Second time is easier...:mad: You might want to take it apart once just to make it easier on yourself if you have to do it on the side of the road. Luckily, I was in the front yard of an extremely nice Asian gentleman who brought out his floor pump to help me out.
I had felt around in there pretty good I thought before I put the tube in, but a couple of blocks later flatted again. Only had the one tube so I patched the original tube while waiting for the Mrs. Axe tow truck. Got it seated and started hand pumping - pump broke.
Got it home, pumped it up with the floor pump and it popped again. :oops: I guess I need to go to remedial tire changing school. I've changed hundreds of tubes - is there something special I'm missing here or should I have just gone back to bed today?
Got 2 tubes and a better pump on the way to work. Guess I'll be watching tire changing youtube videos for lunch.
That happened to me on my Silvio one day too! 2 flats in the same day.
Welcome to the school of hard knocks!
I was so frustrated in hard hard it was to remove and re-mount the wheel. It was raining too.
After that, and reading all the posts on this forum I got better at it!
  • Like
Reactions: joy
Did you find the location/shape of the holes in the tube?
The hole in the tube matched the hole in the tire. Felt around in the tire and didn't find anything sharp. I didn't check the wheel, though. Thorough review planned before I put the new tube on.
Suz
Oh my! Good advice. I haven't had a flat yet (fingers crossed) and going on a big trip in June so I'll be practicing the wheel removal.
Pretty lucky to have a guy bring out a floor pump - how ironic is that?
Best thing you can do is zip-ty the fork to the chain-stay so they don't separate. Just leave it there all the time
Think I found my issue - it matches the latest tube hole. Of course all of the bike shops in town are closed now so I'm out of luck for tomorrow morning. I don't have any experience with these tires. Are they not very reliable? Can you patch the tire itself or is it like a car where the sidewall is basically not patchable?
What brand of tire again?
Conti and Schwable will let you file claims on new tires that fail immediately after a few weeks you'll have new tires. That's good because as you just got reminded it's always good to have 1-2 spares on hand (and best stored in a cool, dark, slightly damp cellar). First rule of tires is the probability of a ruined tire is inversely proportional with the difficulty of getting a replacement. The replacements can be you spare. I have about 70% success getting tires warrantied. If you don't like spare tire laying around unused; all the more reason to have a spare bike! :D
Prior to this foray into Bontrager tires I was firmly a Schwable Snob and will be going back to try Schwable One's
Whoops - Panaracer D Evo 2
If you had to buy Bontrager, which would you recommend - my closest bike shop is Trek, and that's basically all they carry. Anything wrong with them?
Yeah Panaracer I don't recall them having a warranty program; I had one do that very same thing on 300 miles.
I like the Bontrager TLR3 and TLR4 that we are riding nothing wrong with the tire the quality is good; now we running tubeless so that's my only experience with that tire; but it's tube compatible.
Schwable just easier to get mail-order and cheaper the TLR4 is expensive especially at a Trek Store. I'm just far enough out in the country to find that better than the 2 hour drive to the nearest trek shop.
Picked up a pair of Conti GTs - I'll put em on this evening and give 'em a trial run. New clipless pedals came in so I put them on last night. For my after dark adventures I also got the Nori-lights installed on the front wheel last night while I had it off, but still need to do the back. Got distracted by a clogged kitchen sink.
According to this article my "ideal" pressure would be 90-100 psi. Was running the Panaracers about 95 because of the wetness for additional traction, but it sounds like that was a good pressure for me anyway. It was definitely a smoother ride while it lasted. Anyone have a pressure suggestion? Planning on a River Road excursion this weekend which means pretty bad asphalt. Better prepared this time - new pump, and will carry 2 spares and a patch kit :)
