what is the wall thickness of the v 1.0 and V 2.0 frame under the seat bottom, to install Open ended knurled Aluminium threaded insert M5 for 0.5 to 3.3 mm sheet thickness or 3.3 to 5.7 mm. These compress down like a rivet to hold the nut solidly.
http://www.totalfasteners.com.au/browse/nut-threaded-inserts-and-tools/202003586
It would be for a set of Terra Cycle Underseat racks without the cross hangers, using the M5 threaded nut inserts in the frame.
http://t-cycle.com/easy-reacher-underseat-racks-c-12/volaehaluzak-rack-p-122.html
Would it be better to use M5 allthread through both nuts inserts (With the thread drilled out on one of them ) to allow external nuts to compress the two nut inserts and hold the clamps to the frame.
regards
Super Slim
regards
Super Slim
