Mudguards for Vendetta
snilard
Guru of hot glue gun
I know that mudguards for V was discussed but I cannot find solution for my problem.
What mudguards do You use for your Vendettas?
I have bought Crud Roadracers MK2 for my V20. On front wheel it was easy to fit it with only small modification. It works nice. On rear wheel I cannot fit it to work without rubbing. Is there anybody who have fitted Crud's mudguard to back wheel of V without rubbing?
I am thinking that I will try SKS bluemels in 35 mm width but fitting Cruds would be much better. This mudguards are not cheap....
i use a rear mudguard only on the vendetta. raceblade sks which is actually the front mudguard i have the actual rear mudguard on my catrike 700 trike so the front was left over so to speak. the front works well on the rear wheel of the vendetta.
snilard
I have fixed rear mudguard on more points, moved it a little bit farther away from tire and changed long splashguard to short one. I think that it will work now. But no pictures yet and no testing yet.
