randyspann
- From your store:
When the Silvio is adjusted to a taller rider the crank gets lower to the ground, as it rotates forward. To compensate, we have produced 100mm and 150mm extentions to the chainstay. When these are used, the chain must be lengthened by 200mm and 300mm respectively.
When you order, let us know if you want the 100mm or 150mm version.
As a guide, if you are 180cm tall, take the 100mm, if you are 190cm tall, take the 150mm. Otherwise, you will probably be happy with the standard chainstay length.
- I have an xseam of 46 inches (117cm?) and my BB height on the silvio is about 1 3/4 inches to 2 inches lower than the seat height. Any idea how much each of the two chain extensions would raise my BB height? I would like to raise my BB height about 3 inches. Which to order!
