This is Brazil
The shop owner offered to get me another axle. But the axle is part of the kit and probably sold only in 100 pieces lot size.
We reach an agreement that he is going to give me a rear hub in exchange for my front hub, so I don't need the supplied axle and will use the rear hub without the cassette.
He said he is going to order the Shimano Alivio rear hub and I can pick it up by end of August.
Well, Brazil is a different reality from USA and it might be very possible that when I go there by end August he will say the vendor didn't have it, that he forgot and is going to order it again etc etc and I'll never see the promised hub.
The time I'd loose suiting the shop is not worth the amount involved either.
I'll wait to see if anyone gives me suggestions on how to replace the dust cover, or will use the wheel without the dust cover and when the hub wears out, replace it by a rear hub.
Or I can try to cold press the frame, as you did, to fit the front hub with its original axle in the rear. But I am afraid I might screw up the frame and end up with two screwed up pieces instead of one
