Rim Brake
chrisblessing
Greetings. In Colin Croft's post regarding his Quest 559/700c (http://cruzbike.com/559700cc-build...finally-ridable) we note that he installed a rear rim brake where the kickstand was mounted. Does anyone know if this is possible with any Quest (1 or 2)?
Thanks.
Chris
From Ratz's VAST garage of
From Ratz's VAST garage of 6+? Quests from V 1 to V3,
V1 559 * 35 (1.3") max front, Disc 700*23 rear with filing some of the kickstand away, Disc OR Rim brake, but its better to have the same sized wheels front and rear.
V2 650 * 35 max front Disc , 650*35 rear with filing some of the kickstand away, Disc brake?
V3 700 * 23 max front Disc+ rim, 700*23 rear with filing some of the kickstand away?, Disc OR Rim brake
See attached photo of a V1.0 with 26" * 32 tyre with lots of space sideways and height.
The 700*28 wheel off my Silvio V1 would not fit, but needed an approx 12 mm off the kickstand bracket in the tyre area to be removed, and I assume that the rim brake uses the kickstand hole.
