I'm in the same stage as Dan and need to confirm my desired running gear. For background I've had the Silvio 1.0 for 14 mths with Ultegra 10 speed, triple chain wheels and largest cog of 28t.
For the 2.0, I would like to stay with Ultegra but current specs do not have the triple.
Proposed gear is:
Ultegra DI2 R785 disc brakes, 140mm rotors, resin.
Cranks, shortest I can get, Compact 50/34
Rear derailleur: long cage (GS) Cassette 11-32
FD: braze on
Queries: Can DI2 battery be internally mounted
By reviewing the Forum it seems the 135mm Hub for discs will fit?
Thanks, Bruce
NB My have to wait for the R785 to go on sale for aftermarket use.
1. For water, I have the Veleau system, this should work well.
2. For storage, I have the Radical bags on the 1.0 which I will try out.
3. For mirrows, I have 2 Zefal Spy.
Proposed gear is:
FD: braze on
Thanks, Bruce
