Ultegra 6800 11 speed (Di2) build question
TEX
I'm doing up my new Silvio S30 with the new Ultegra 6800 11 speed (Di2). According to posts on your site i'll need "Shims for the smaller BB diameter. 1 3/4" outside X 1 5/8" inside x 3/8" wide." True?
.... Where would I get these?
scabinetguy
6800 shims
Online metals.com....... Just order a small section of 1 3/4"x 1 5/8" aluminum tubing and cut the shims the width you want. I have a lot of miles on mine so far, no problems.
telephd
TEX,  I just went through
TEX, I just went through this as well. I ended up sourcing and purchasing a Dura Ace 7900 BB with the standard sized bearing cups. If you want to go that route I give me a shout and Ill give you the hookup.
Hal
BrianA
Shimano 6800 BB
Hi Tex, Have to agree with telephd. I recently built a Silvio S30 in Canberra with the Shimano 6800 11 speed groupset and ended up buying the Dura Ace 7600 BB from my LBS. Personally I would rather have the chainstay fit the BB as designed without the use of shims, which are more likely to come loose. I'm sure that a google search will put you in touch with several bike parts suppliers with this BB in stock.
