My Vendettas
11 replies [Last post]
John Tolhurst's picture
Offline
__________________
Architect, Planner, Business Analyst. Cruzbike original designer, inventor, proponent, technical curator, keeper of the mission.
ak-tux's picture
Offline
Share
Wow! Built with precision!
Wow! Built with precision! Those hydroformed tubes look very light too! probably the new V is significantly lighter than the current one.
What are the short pipes just beneath the main frame where the rear stays joins the bottom of the main downtube?
Jerrye's picture
Jerrye
Offline
Share
A guess...
"What are the short pipes just beneath the main frame where the rear stays joins the bottom of the main downtube?"
If I had to guess, I would say an anchor point to assist in welding up the frame - a jig positioning point. But that's just a guess.
Looking good John!
Charles.Plager's picture
Offline
Share
Given that this bike doesn't have a bottom bracket "where it should," your guess makes a lot of sense.
Offline
Share
Correct, the BB on a DF is
Correct, the BB on a DF is used over and over again for holding the frame while some operation or other is done. Rather than invent a whole new way of holding the frame, they all get a BB welded to them, and they all get them cut off.
__________________
Jerrye's picture
Jerrye
Offline
Share
That's a first!
You mean I was right about something? Shock Good thing I have it publicly posted!
Dreaming about a V...
Andrew 1973's picture
Andrew 1973
Offline
Share
You know what I'd love?
I'd love to have one of these in the unpainted state. I have been wanting to do another one of these finishes and starting with a bare frame rather than having to strip paint would be a real time-saver.
Haro Extreme Comp - Painted by Andrew Baloga
I bought the frame for this bike as a complete mountain bike that needed more work than it was worth. The original finish was gone and had been previously repainted a brown/copper colour which despite being chipped and scratched, it was a pain to remove. The brushed finish was done by hand with varying levels of abrasive sheets and after masking, the blue and red candy coats were applied. After adding a few decals, the entire frame was sprayed with a two-stage urethane clearcoat.
I shouldn't have sold this one. Sad
Andrew 1973
Offline
Share
Inadvertent highjack
Sorry about the shameless plug for my self-percieved sense of aesthetics.
Back to the Vendettas...please.
fastpastprime's picture
fastpastprime
Offline
Share
*my Vendettas*
 I think one of those is mine now. So like I asked before... how many Vendettas are out there total. You avoided the question before. Is this some trade secret? I see maybe 40 and assume these are the 2.0 version. Add in two previous production runs and I'm guessing under 200 worldwide.
BentBierz's picture
BentBierz
Offline
Share
Excellent attention to detail...I looked at the frames and took absolutely no notice to these tubes!
__________________
Larry
Friendswood, TX (Houston Metro Area)
'13 Cruzbike Silvio 2.0 | '13 Barcroft Ti Virginia | '10 HP Velotechnik Scorpion FS | '10 Easy Racer Folding Ti-Rush | '02 Airborne Ti Carpe Diem
marshall2389's picture
marshall2389
Offline
Share
those pipes are used during
those pipes are used during production to keep the frame held stable.  They are removed later.
__________________
Elliot
Offline
Share
Correct, nearly all the
Correct, nearly all the factory frame tools presume the existence of a BB on the frame. So rather than rebuild the factory, we just add a temporary BB to the frame.
__________________
