New Silvio build
25 replies [Last post]
mikethebike's picture
mikethebike
Offline
Yesterday I completed the assembley of my Silvio. Very straight forward apart from two minor issues:
   1/ The hole in one of the rear dropouts for the bolt securing the dropout to the chainstay was mis-aligned. Seems to be drilled in two sequences, the top hole from the top and the bottom hole from the bottom. These two drillings were not aligned so the bolt wouldn't go through. A little brisk work with a round file fixed thatsmiley
2/ My front derailleur, SRAM Force, wouldn't go far out enough to move the chain to the outer ring. Using a suitable bit of pipe to give purchase, I carefully bent the derailleur stalk to the right a few millimeters. Fixed.
Apart from that, as said, no problem.
I will however, admit that I'm a bit disappointed that the gap between tyre and fork crown is so narrow that it won't permit passing a standard fender through. I live in a wet climate and riding without fenders means both rider and bike get very dirty. It'll have to be a McGyver solution with two-part fenders.
John Tolhurst, you seem to read most of what is written on the forum so I hope you will be reading this. Any objections to glueing a 90-degree "angle-iron" of plastic to the chainstay to give a fastening point for the end of the fender?
Also, at some future time, how about including drilled and tapped holes on the front dropouts or fork ends, as fastening points for a fender, same as there are on the rear dropouts. Ok, I realize that the holes actually are intended for attaching some sort of rack or low-rider frame.
Enough about the build, after that it was time for a trial ride. Wow, like riding a snake, this will take some time getting used to. My previous ride, a Velokraft VK2, is sleek, black and fast so I affectionately called it the Black Mamba. (Before that I had a green M5 Shock Proof which, of course, was the Green Mamba). The Silvio, with it's snakelike feel, will have to become Black Mamba II cool
John Tolhurst's picture
Offline
Share
Silvio (and Vendetta) are
Silvio (and Vendetta) are specified to follow what you get on road bikes. This means fork clearance and many other things so that components work out of the box, as far as possible. Look to road bike accessories.
Gluing to the head of the chainstay might be an option, or putting longer bolts through to carry the angle.
The rear dropout bolt holes for connecting the ends of the chainstay are not misaligned, as this part is CNC machined. There might have been varying paint thickness, perhaps, or the chainstay end not quite position - but either way you have resolved it with a bit of thought.
__________________
Architect, Planner, Business Analyst. Cruzbike original designer, inventor, proponent, technical curator, keeper of the mission.
Andrew 1973's picture
Andrew 1973
Offline
Share
Fenders: SKS Raceblades?
While the lower derailleur cable interferes with the standard attackment point for SKS Raceblade fenders, I think that they come with an aero fork attachment (a shaped, plastic sleeve) which might serve as a pass-through for the cable. Just a thought before you have to MacGyver a solution.
Andrew 1973
Offline
Share
AttachHment.
Andrew 1973
Offline
Share
That might not work
My idea about the SKS Aero Adapter might not work, but maybe you could fit a section of cable housing over the cable run to the lower (rear) derailleur and rest the SKS attachment on that. The fenders are held on with zip ties or rubber straps, and I can not imagine either would apply enough force to the cable housing to cause internal drag and compromise shifting.
Does this make sense? I feel I should illustrate this instead.
georgec's picture
georgec
Offline
Share
mikethebike said: > I will
I agree with you!
I tried the SKS Raceblades, but, because of the problem that Andrew mentions, I could only get
the rear mounting bracket to work on the front of the bike. Even with the rear fender mounted
on the front in this way, I found the protection to be inadequate. So...been there, done that, and
don't recommend it.
I studied and tried other road bike solutions, but could not find anything I thought would really
work for me.
I ended up mounting two 35mm wide full length Rear fenders (from two SKS P35 sets) on my
Silvio (Because, you see, the Silvio really has two rear wheels).
Note: This required mutilation that some might find offensive Smile
NeilJ's picture
NeilJ
Offline
Share
Mr Crud Road Racer Mudguards
Mr Crud Road Racer Mudguards are fitted to my Silvio. Fitting was fast & easy as per the instructions. I am using 25c tyres.
http://www.youtube.com/watch?v=JuyRZ3hAjrU
Offline
Share
>I agree with you!
hmm ... but if I raise the fork crown standard road callipers are no longer sitting where they should. Does this not matter?
__________________
Andrew 1973
Offline
Share
I personally wouldn't want to
I personally wouldn't want to see increased clearance. The Silvio is a performance road bike and giving fender clearance while requiring long reach caliper brakes would affect the aesthetic. Neilj's fenders pictured above seem like a good solution.
Charles.Plager's picture
Offline
Share
Fat Bottom Tires Make the Loving World Go Round....
Hi,
When I was looking into DF bikes (before I saw the light), I was planning on buying a cyclocross bike instead of a straight-up road bike.  Partially because the geometry is more relaxed and partially because they are basically road bikes that allow much wider tires (or wider tires and fenders).
I completely understand that Cruzbike needs to market its bikes so that they get sold and that I'm probably a minority here.  But I'd love to see the high end bikes with more room for bigger tire clearance.   Riding on crappy streets and MUPS, etc...
And as long as I'm asking for things I'm not going to get, I want a red Silvio (or Vendetta) too. Laughing out loud
randyspann's picture
randyspann
Offline
Share
Red Silvio
 - Red Silvio - blasphemy!
__________________
Randy - Silvio 1.0, Chainstay Extension, Ventisit
mikethebike
Offline
Share
Alas
I have chosen 28 mm tyres which means that the gap is too narrow even for raceblades.
But I have put the thinking cap on and have come up with a solution. Requires slaughtering two sets of standard fenders but I think it will be worth it. Done half of it but now I need to take a trip to the LBS. Will post pix when I'm done.
Anybody out there with good ideas on a chain guard. Riding in a group with an inprotected chain ring in front of the bike is seldom popular.
Two solutions, a/ make sure you are always first in the line cool  b/ put some sort of protection on the chain ring. Ideas anybody?
Andrew 1973
Offline
Share
Raceblades...
Not that it matters, but Raceblades do not go under the crown or brake bridge, so tire clearance is not an issue.
Kim Tolhurst_2's picture
Kim Tolhurst_2
Offline
Share
Chain wheel guard
yes,  drperry, this site has a hand made chain wheel guard mod. I will ask him to post pic.
Kim.
Dennis Perry's picture
Dennis Perry
Offline
Share
CHAINRING GUARD
I bought my chainring guard directly from ICE Trikes – in the UK (http://www.icetrikes.co/community/contact-ice) - and they told me the chainring guard wouldn't work. But I already knew that because the BB on the Silvio is "different". My LBS jury rigged something, which is UGLY, but it means I don't poke people with the big ring.
A design oversight, if you want to be seen to play nice with DFs. My Quest V2 came with an integrated one.
You can see the ICE trikes one properly fitted, and perhaps buy it from http://www.utahtrikes.com/PRODINFO-tricechaingurd.html
I also bought another chainring guard which Velotecknick make, see: http://www.hpvelotechnik.com/produkte/spm/details_e.html and scroll down.
I got it from Hostelshoppe, and it attached by screwing it up with the bottom bracket. It was SUPER UGLY, and Hostelshoppe appear not to stock it now, but have the ICE unit, see:  http://www.hostelshoppe.com/cgi-bin/readitem.pl?Accessory=1231971527
My all time favourite has to be from: http://www.hembrow.eu/chainringguard.html
georgec's picture
georgec
Offline
Share
No need to change the caliper location.
Hi John,
By removing about 2-3 mm of the fork crowns, front and rear, with a half-round file I was able to get
SKS P35 fenders installed with Conti gatorskin 700x25c tires and Shimano Integra brakes. I stopped
fileing when the fender started touching the brake caliper inner surface. So nothing about the wheel/
brake/rim setup is changed. It is tight, but seems servicable. I will know more once muck starts
accumulating inside fenders.
mikethebike
Offline
Share
Almost done now
I have now attached most of the extra bits and pieces that I wanted.
Mudguards/fenders: since I live in a wet part of the world and prefer riding a bike to cleaning a bike, fenders are a must. having beforehand bought 28 mm tyres there was no room for stndard mounting of standard fenders. After some thinking I did as shown, using up two sets of fenders in the process. My rack is a left-over from a kiddies bike. I cut off the vertical struts and replaced them with 8 mm aluminium (aluminum for the Yanks) tubing cut to suitable length, flattened the ends and drilled holes so I could attach them to the thread inserts on the rear seat stay. For the front end support of the rack I used a piece of 3 x 30 mm aluminium bar which I drilled and sandwiched between the suspension link and the seat stay link plate. I substituted the M5x12 bolts for M5x15. I also removed the pre-load plastic spacer.
The rack will at no time be carrying any greater load. Normally just support a Carradice saddle bag. For longer tours I have a pair of Radical recumbent bags where the rear ends are supported by the rack but most of the load is taken by the straps over the seat.
I have SRAM RD and FD and brifters. Shimano Ultegra brakes. 50/34 chainwheels and an 11-32 SRAM cassette.
Remains: A chainwheel protection. Working on that but I might end up putting on a Catrike rotating guard from Hostel Shoppe.
Between tinkering and other business of life I have only managed to put i 40-odd miles, some of it without fenders which can be seen on the bike. Feeling a bit more confident but now winter has decended on us so streets and roads sre smothered in snow putting an end to outdoor training. Spring feels a very long way offsad.
Offline
Share
Hi Mike, Looking nice!  Well
Hi Mike,
Looking nice!  Well done.
By the way, I think you want the trainer to face the other direction so the wheel is turning the same way it would for a RWD bike.  (And, for the record, I would have done it your way too until John pointed it out. Smile ).
Eric Winn's picture
Offline
Share
In your third photo above, I
In your third photo above, I would be tempted to put some sort of rubber pad between the fender tab and fender edge and the chainstay to prevent the tab and fender from abrading the chainstay arms. It might also help the tie-wrap hold everything in place better.
Do the extensions cause that area of the chainstay to flex more than without the extension? If so, even more reason to monitor for abrasion issues especially since your photo shows that will be an area to collect road grit and grime.
Nice stable of bikes in the background. How does the Raptobike compare to the Silvio? I was contemplating Arnold's Mid Racer before stumbling onto the Cruzbike site and ended buying a Vendetta after test riding a Silvio wink
kenhardwick's picture
kenhardwick
Offline
Share
Trainer Position
>>>>>By the way, I think you want the trainer to face the other direction so the wheel is turning the same way it would for a RWD >>>>>bike.  (And, for the record, I would have done it your way too until John pointed it out. ).
>>>>>Cheers,
>>>>>   Charles
Charles..Thanks for pointing that out. I just received my new trainer Friday and did the exact same thing when I mounted my Silvio to the trainer. Took it off since as the temp have been in the 70's here in Oklahoma but will plan to put it back on correctly next time.
__________________
Ken Hardwick
Norman, Oklahoma USA
mickjordan's picture
mickjordan
Offline
Share
Cycclops trainer alert
Beware of the Cyclops trainer. My Silvio fell out of it on the first ride and I concluded that, given that you cannot get a properly sized trainer skewer for the Silvio, it is not safe as the clamp hole just doesn't accept the skewer in a safe way. I swiched to my Kinetic (yes, I had two trainers!), which has a much better and safer attachment scheme.
mikethebike
Offline
Share
I forgot to mention
Eric Winn: The fender tab is glued to the extension using silicone compound exactly for the reason you state.
The Rapto isn't mine but belongs to my brother in law, we share a two family house. It's too small for me to ride. The Velokraft VK2 however belongs to me and has been my primary ride for the last five years. A wonderful bike thet I have really enjoyed. But then suddenly you get the itch to try something new wink. Also, at the age of 67, I was beginning to have issues with my feet going numb so I wanted a bike where the feet were lower positioned. And thirdly, I wanted to sit higher to get a better overwiew of traffic and to fit in better with DF riders.
About the trainer, I have so far only been using it as a convenient stand whilst tinkering. But I must admit that i wasn't aware that the rotation direction mattered. Can anybody explain why?
georgec's picture
georgec
Offline
Share
Nice Fenders!
Nice to see an installation of functional fenders on the Silvio. Great job!
It looks like you cut gaps in the fenders for the forks. Is that correct?
Offline
Share
Almost. Smile
The trainer cylinder (what the wheel rests on) will spin the opposite direction that it was intended.  It's possible that this is bad for some trainers.
Also, the frictional force between the wheel and the cylinder will now point in opposite directions.  This might mess things up too.
As far as I can tell, it is no worse than putting a fixie on a trainer and pedalling backwards.
mikethebike
Offline
Share
Fenders
Yes Georgec, you are correct. I've had to cut the fenders since they won't fit between the tyre and fork crown.
Mickjordan: On my trainer there is a slot in the holder (the "fixed" one, not the one with the clamping mechaninsm) that will take the skewer lever. So I'll have to reverse the skewer so that the skewer handle is on the non-drive side. No risk at all of the bike falling off.
Offline
Share
Well, I had a trainer with a
Well, I had a trainer with a fan. I rode it backwards, so the air pressure was pulling the blades outwards, instead of pushing them against one another, then one day it .... exploded on me! ha ha Had bits of fan blades all over the place.
__________________
