Squeaking in boom area
13 replies [Last post]
paulbostick's picture
paulbostick
Offline
Anyone having a creak or squeak in the boom area of their Silvio 2.0.I have a creak in mine under stress or when going up hill. I have all Allen bolts good And tight.also three flat tire in three days on front
Andrew 1973's picture
Andrew 1973
Offline
Share
Noisescan be hard to track down...
...I had a creaking sound that I thought was my bottom bracket; my mechanic agreed and tighfened the BB, cranks.and pedals. The sound was still there. As it turns out, my rear skewer was worn out.
That said, grease and a torque wrench are good to have when going over your boom. I would lightly grease all sliding fittings and any bolts. If the bolts have blue LocTite on them, then just go with that - no grease. My boom on my Silvio v. 1 creaked a little until I gave every bolt a once-over.
Jeremy S's picture
Offline
Share
After adjusting my boom, I
After adjusting my boom, I heard some serious creaking during my ride today... but it went away on its own after a few miles.
__________________
Jeremy Smoler
Silvio 2.0
Sofrider V2 (sold)
scabinetguy's picture
scabinetguy
Offline
Share
I had that noise
        I found that the noise was do to my upside down installation of the tapered bearing sleeve on the front fork.
MrSteve's picture
Offline
Share
Wheel?
There are a lot of parts in a wheel assembly.
Make sure that your drive wheel is true, tuned, lubed and undamaged!
-Steve
__________________
"Me, we."
-Muhammad Ali
Drew's picture
Drew
Offline
Share
I had a couple squeaks that
I had a couple squeaks that developed after 500 km.   The first problem was the seat pan fit.  This was corrected with rubber washers on the front bolts.
Next, I loosened every bolt on the front end along with the front skewer and pivot clamp.   I lightly greased where I could (bolts,  rear shock elastomer and front shock boot) and torqued the bolts again.   The squeak is no longer there.
Before I did this work on the front end I had a BB clamp bolt shear off while I was riding.  I noticed after my front derailleur jumped out of alignment as the BB clamp shifted.   I may have over-torqued that one bolt so be careful and learn from my mistake.
Rod's picture
Rod
Offline
Share
I have heard a creek a few
I have heard a creek a few times on my Silvio 1.5, I did not see any info on what to torque any of the bolts. Does anyone know what that should be for the various bolts?
__________________
Rod
BentBierz's picture
BentBierz
Offline
Share
Drew said: I noticed after my
I love my torque wrenches. While assembling my Silvio 2.0, I am hard pressed to think of a fastener I haven't torqued yet. For frame fasteners that don't have a documented torque, I have a general purpose chart hung on my garage bulletin board that lists values for dry and lubed fasteners.
I'm sure some will call it unnecessary but I'm not working in a high volume bike shop where time is money and I tend to strong arm fasteners way too often...not something you want to do on a bike.
__________________
Larry
Friendswood, TX (Houston Metro Area)
'13 Cruzbike Silvio 2.0 | '13 Barcroft Ti Virginia | '10 HP Velotechnik Scorpion FS | '10 Easy Racer Folding Ti-Rush | '02 Airborne Ti Carpe Diem
Ivan's picture
Offline
Share
Larry, what torque wrenches
Larry, what torque wrenches are you using and do you have a URL link to them?
__________________
SINGAPORE | Silvio 2.0 | Brompton S2L-X | Silvio Photoshoot | Silvio Photo Chronicles
Eric Winn's picture
Offline
Share
I have a Topeak D-Torq Wrench
I have a Topeak D-Torq Wrench DX. I like it a lot. It includes a case and various bits and has a range of 4-80 Nm which is perfect for bicycle parts. Pretty expensive but very nice.
http://www.topeak.com/products/Homeshop-Tools/dtorq_dx
Jake514's picture
Jake514
Offline
Share
Thanks Eric
You answered one of my questions in my mental queue.
Eric Winn's picture
Offline
Share
Mental telepathy is one of my
Mental telepathy is one of my other talents but strangely it doesn't work with people's psychic turn signals...
thaddeus's picture
thaddeus
Offline
Share
Creak in Silvio 1
Here's my post on how I solved the creak in my secondhand Silvio 1.0, having first ensured that the BB clamps were correctly adjusted for my X seam  (and not the first owner's):
http://cruzbike.com/creak-solved
Best of luck,
Warwick Dunbar
Melbourne
ratz's picture
Offline
Share
Had the creaking front end on
Had the creaking front end on the Vendetta. Turned out it was a bad front Skewer. Put my spare CB provided one in and poof all golden. I like simple fixes.
__________________
Bob Pankratz
Silvio 2.1 build diary, Summer Cruz the movie, Quest for Ice Cream,
Night Rider official trailer, Ride with Flare coming this fall,
Rolling the Rollers and crashing
12 bikes or 1 boat, no contest and that's before you factor in the cost of gas. The 3 laws
