Tiltmaniac's S30v2 build.
tiltmaniac
No-flash (daytime looks):
Flash-on (nightime looks):
Happily, I was able to get an S30v2 and transplant components from my second S30.
More pictures start again here: https://cruzbike.com/forum/threads/tiltmaniacs-s30v2-build.12220/#post-143148
Here is the BOM:
Lights:
+Front
- Light&Motion Seca 1700
- Blitzu Cyborg white bar flashy
+Rear
- Fly6
- Garmin Varia radar (and rear flashy)
- Denotte Daytime red taillight (pointed down to light up the road)
- Serfas UTLA-8 Blast tail light
Bottom Bracket:
- Xd-15 with GXP sleeve adapter.
Cranks:
- Bikesmith shortened Sram Apex Compact double (155mm)
+ Chainwheels
-34t q-ring
-52t qxl aluminum
-Shimano PD-M9000 spd pedals
Derailleur:
+Front:
- Sram red braze-on
+Rear
- Sram X0 type 2.1
Bars:
+Shifters
- Sram Force double-tap
+Mirror
- Ortleib Ultralite Bike Mirror
+ Gps and horn and mount
- Minoura SWG-400 (modified)
- Garmin quarter turn
- DAWAY A14 Loud Electric Bike Horn
Front driven wheel:
- Flo45 clincher 32h
- Powertap G3 disc+powertap rotor
- Sapim cx-ray j-bend 262mm black spokes
- dt-swiss squorx 22mm alloy nipples
- Sapim HM nipple washers
Rear undriven wheel:
- Flo45 clincher 24h
- dt-swiss 240s straight-pull centerlock disc hub
- Sapim super cx-ray straight-pull 272mm black spokes
- dt-swiss squorx alloy nipples
Cassette:
- Sram PG 1030 11-36
Seat:
- Thor Carbon Sport G XL
- ventisit classik (2cm) thick cushion
- mounted with thermoplastic anchored with bolts in front and into the headrest rail clamp
Brakes:
+ Front
- Yokuzuna Motoko mechanical/hydraulic
+Rear
- caliper
- Cables
+ Front brake
- Jagwire Elite link brake housing
+ Rear brake
- Jagwire brake housing
+ Derailleur housings
- Jagwire 4mm derailleur housing
- Jagwire J2 inline shift cable adjuster(s)
+ Cables
- generic Teflon brake and shift cables
Storage:
- Bentupcycles BUC seat bag small
Pump:
- Topeak Road-Morph with gauge
Tires:
Continental GP4000sII
Chain:
- kmx X11SL (gold/ti-ni)
Safety:
- RydeSafe (retro)Reflective decals (black, red)
- LiteMark lemon-yellow (retroreflective) variety pack
Anti-flop device:
- Grifiti Band Joes silicone rubber 18" band
( This is looped over the boom, "braided", and hooked around the thumbscrews on the lower seat bolts/under the seat)
Rides quite nicely in it's maiden voyage to and from work today.
The cables are too long-- they'll be cut after some more miles are in the bike and I'm sure I won't be adjusting the boom about.
nobrakes
I like your anti flop device. When I built the V20 I knew that people were saying the front is a pig to handle when off the bike, but I didn't realise it could masquerade as a wrecking ball and chain, tasked with random attempts to knock down all walls within a 3 foot radius :)
tiltmaniac
Thumbscrews used (important to keep rubber band from cutting on sharp edges):
http://www.mcmaster.com/nav/enter.asp?partnum=96115A450
I also put some edging on the Thor seat, primarily to protect it when leaning against stuff (I commute on the bike), but it also helps to prevent the rubber-band from being cut by the carbon-fiber seat edge.
Edging:
https://www.amazon.com/gp/aw/d/B00NL49DCS?psc=1&ref=yo_pop_mb_pd_t2
This edging is larger than it needs to be, and thus heavier than it needs to be, but I've not been worried about getting that detail perfect.
tiltmaniac
Do you use both bands or just one? And do you leave them attached even when you ride the bike?
One rubber band, but long enough (18" un-stretched) that it loops over the boom. I've also done it with two or three rubber bands, but that requires either zipties or boom disassembly to mount, or you end up with a wider knot down lower which wears out faster.
I leave it attached all the time. The rubber band isn't strong enough for me to notice it when riding (steering deflection isn't that big during normal riding)-- it mostly helps with moving the bike one-handed, to prevent the bike from falling down when parked (e.g. against a wall), and preventing boom-strike against the rest of the bike.
The rubber band has lasted for 600 miles without significant wear, so I expect it to keep on going for another 400-600 miles more. If you buy 'em in larger quantities, the cost is $5 per 1000 miles. Pretty cheap :)
tiltmaniac
Here is the GPS and horn mount. I described the modification I did to make this work in another thread.
I mount the GPS there as it is guaranteed to not get knocked about when I sit up (as I have plenty of stops and cars to contend with, I sit up many times each ride).
tiltmaniac
How did you braid the band? Looks like it wrapped within itself.
I took each end, twisted it 180 degrees, then put the end closer to me through the one farther (both 'ends' are loops since we've stretched the middle of the band over the boom). Repeat until happy with the result.
tiltmaniac
Detail on the seat mounting.
I still seem to be the only one doing it this way, which I find perplexing. Maybe these photos will help?
The first three here are a quick look at how the seat looks while mounted:
IMG_20180226_201411.jpg IMG_20180226_201418.jpg IMG_20180226_201434.jpg IMG_20180226_201423.jpg
tiltmaniac
In this sequence, I install the bottom thermoplastic shim, then the top thermoplastic shim, then I show how the bottom of the seat fits.
If you pay close attention to the 6th or so photo, you can see the Perez clamp installed.
The top seat screw goes into the top hole of the Perez clamp.
This is the modified Perez clamp, where I drilled out the middle so bolts could pass through, and put the rod on the side.
IMG_20180226_204927.jpg IMG_20180226_204924.jpg IMG_20180226_204919.jpg IMG_20180226_204915.jpg IMG_20180226_204906.jpg IMG_20180226_204908.jpg IMG_20180226_204911.jpg IMG_20180226_205007.jpg IMG_20180226_205010.jpgIMG_20180226_205013.jpg
tiltmaniac
How the seat-bag is mounted.
This is not as light of cool as the CF racecase, but it is easily removed for commuting, which is what this bike is for...
It doesn't require any bolting, strapping, etc. You just slide it on and you're done.
IMG_20180226_210106.jpg IMG_20180226_210110.jpg IMG_20180226_210118.jpg IMG_20180226_210130.jpg
